Discuss Support / Fitting Limestone Coving in the UK Tiling Forum area at TilersForums.com.
Rizzle from the Portizzle
if this is a shelf drill 8mm hole 60mm deep into centre of shelf 4 holes 100mm in then every 200mm now put bolts in to wall using apoxy resin leaving 58mm of the thread sticking out. now fill the drill holes with apoxy resin about half way .and run a line of the resin down the back of the stone now push the stone on to the studs and push back intill it makes contact with the wall now let set /ps tape round the wall where the shelf is going to stop the apoxy sticking where you dont want
Ceramico tiling
You should definitely get some mechanical fastening on that slip.I would use threaded bars and set them 10mm into the stone with resin.If you keep the holes tight the bars will set straight. I would then get my holes on the wall perfect.I would make sure theres a good 40mm into the wall.There is a nice product called Green 300 Anchorset. It is a resin that has a long applicator nozzle that both mixes and lets the resin start right at the back of your holes in the wall.Threads are supposed to be turned into a hole filled with resin but thats not going to be possible.So deff use adhesive aswell. Just be carefull about the drying times with Green 300 if you decide to use it.
Reply to Support / Fitting Limestone Coving in the UK Tiling Forum area at TilersForums.com
Forgive me for I am noob... I have a 9m x 9m floor area that is one space, but half is a new...
I would very much appreciate the advice of anyone who has fitted Marmox boards as I have decided...
6K
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
