Discuss Suspended floor - Can it be tiled? in the Australia Tiling Forum area at TilersForums.com.
I
inspiredandy
Evening folks....
I have a slight issue I could do with another opinion on. I priced a job a few weeks back to install travertine over a timber floor. Included in the price was the supply and fitting of a decoupling membrane and the removal of the existing floor coverings (carpet and Karndean/Amtico). Having stripped the existing coverings it turns out that the floor is actually floating. I have informed client that the floor also needs over boarding with backer board but they are reluctant to spend the extra money. Bear in mind the area is approx 45sqm.
They have suggested they sign a disclaimer admitting liability and to carry on with original plan. However, I'm not happy to proceed knowing that the floor is likely to fail. I am sure that the disclaimer wouldn't stand up in court as I have advised them of the correct installation procedure and would therefore be negligent if I carried on even with them signing a disclaimer.
A bit long winded I know but would appreciate another judgement.
Thanks in advance.
AliGage
Subscribed
4,531
1,188
Peterborough, England
Need to check if it is a floater or you have a fixing first.
But you've answered your own question in your opening post. If they're not willing to have necessary prep done then walk away. Let it be on their heads not yours.
The prep I did on the floor @Bri is referring too was extensive. It worked but I couldn't guarantee it would and the client was well aware that if it didn't take out the deflection we couldn't tile it.
Thankfully it did. Worth taking your laser round and popping It on the deck and visually show them the bounce. You may find them more persuasive if you show them the problem
Reply to Suspended floor - Can it be tiled? in the Australia Tiling Forum area at TilersForums.com
Does anyone have a DIY link or suggestions for removing just a single central tile from a...
Hi everyone. I’ve just taken on a large refurbishment of a property. Ive taken the job on from a...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
