Element
Hi Folks,
I have a client that has had a swimming pool built and I am shortly tiling all of it's room floor surrounds (not the actual pool itself; someone else is doing that). The floor tiles around it are 600x600 porcelain non-slip about 8.5/9mm thickness. The client is trying to source bullnose tiles to be fitted around the floor /pool edge perimeter but so far has had no success with anything appropriate.
Can anyone suggest or recommend a company that can supply such tiles? Ideally they need to be 8.5/9mm thickness and wouldn't it be perfect if they were 600 wide too - highly unlikely - but tbh, anything bullnose of the right thickness would be a bonus as it is likely to hold up the finished job.
Thanks for your advice
