Discuss Tanked Travertine Shower Problems in the British & UK Tiling Forum area at TilersForums.com.
Creedy
The shower was tanked using BAL WP1, I have a travertine walled and a marble mosaic floored shower. The mosaic was laid first wall to wall. The tiles were then fixed on the walls. The join between the wall and floor was grouted and Silicon sealed. Every month or so i have to remove the Silicon sealant as it goes mouldy. When i remove the Silicon, water literally runs out of the join between floor and wall. Could this be because the walls have not been grouted and sealed properly and the water is penetrating the tiles ?
Creedy
The tiler never put the Silicon on the joint and asked if i could do it for him as he forgot. It was part of my self build project.
The problem i have, after ripping the tiles off this morning, is that where the glass door meets the wall and step into the shower, it has not been grouted/sealed properly. This allows water behind the wall and steps but it has nowwhere to go.
Then because of the Silicon i used it runs behind the Silicon all round the shower, only to be released when i pull off the Silicon.
I am using a sandstone grout sealed with REPOIL.
Is this completeley waterproof, i.e do i need the Silicon around the bottom tiles ?
Have you ever seen water penetrating through a travertine tile ? on looking closely the tiles have tiny holes which have not been filled with grout.
Thanks in advance.
guy1976
the tanking acts as a waterproofing membrane behind the tiles because grout is not waterproof its water resistent and will still allow water to pass through it. so when you pull the Silicon off the wall joints there is water present because the tanking is doing its job by not letting water through the subwall to damage plasterboard.to reduce the Silicon from going mouldy when you take a bath or a shower keep the room well ventilated
Reply to Tanked Travertine Shower Problems in the British & UK Tiling Forum area at TilersForums.com
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
  • Sticky
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
