V
vince365
Hi,
I'm planning to install a shower cubicle with a concealed shower valve and I'm concerned about maintaining a watertight installation of the tanking.
I know the valve face plate will be sealed against the tiles using a silicon bead, but I thought the problem was that tiles and grout can be pourus - therefore water can get behind them which is why tanking needs to be installed.
With a waterproof tanking membrane behind the tiles the water can't penitrate any further and will effectivly run down behind the tiles and back into the shower tray.
If there is a gaping hole in the membrane to accomodate the recessed shower valve then surely any water running down the membrane at this point will find a path into the wall?
Am I right to think this could be a potential problem and if so what's the standard method for ensuring a waterproof barrier is maintained?
Cheers,
Vince.
Cheers,
Vince.
