Pompey Monkey
Hi,
I'm a DIYer in the process of fitting a walk in shower into my bathroom. I've not attempted any project as big as this before, so please be gentle with me!
I am fitting 2" by 2" wooden studs in a cross-pattern to two walls for my shower area. I an using two layers of studs to conceal some existing pipework. The studwork will have the horizontals attached to the brick work wall on 400mm centres with the verticals screwd to these, again on 400mm centres.
On to of these, I plan to fit the Aquapanel boards, just using the vertical studs with no noggins, as shown in the Knauf installation guide. This will result in each panel being attached by around 20 screws.
Unfortunately, I cannot source the ceramic coated screws recommended by Knauf for attaching the boards to the studs and will be using phosphate coated screws instead.
Because I will not be using the correct screws and to protect the studs from unnecessary exposure to moisture, I intend to tape and tank the boards using something like the Bal WP1 liquid, before tiling.
Now for the questions:
Am I right to be concerned about the studwork and screws being affected by water or is the tanking overkill?
Can I apply the tanking liquid direct to the Aquapanel and tape without priming?
Are the vertical studs sufficient to support the Aquapanel boards and tiles (as shown in the Knauf literature) or should I fit noggins too?
Thanks in advance!
Thanks in advance!
