Discuss Tanking area and preparation in the British & UK Tiling Forum area at TilersForums.com.
cgadmin23
Hi All,
I recently purhased a Tuff 2 former and tanking kit (Dura WP) and am about to start laying the membrane. Before doing this can you please tell me if I need to prime the floor surface first? The floor is a 22mm plywood substrate which has been sealed using BAL Bond SBR on the bottom and sides. Do I need to prime the top surface and if so what primer do I need to use.
Also my tanking kit is 10m. I have a Tuff2 tray former that measures 1300 x 800. Should I be tanking the entire bathroom floor or just the tray former area?
Any help and advice appreciated.
Kind regards
Chris
wetdec
Emailed you earlier m8 :
Hi Tony,
I recently purhased a Tuff 2 former and tanking kit (Dura WP) from yourself and am about to start laying the membrane. Before doing this can you please tell me if I need to prime the floor surface with first? The floor is a 22mm plywood substrate which has been sealed using BAL Bond SBR on the bottom and sides. Do I need to prime the top surface and if so what primer do I need to use. *Depending on Adhesive supplier recomendations*
Also my tanking kit is 10m. I have a Tuff2 tray former that measures 1300 x 800. Should I be tanking the entire bathroom floor or just the tray former area? *Yes All of it you should have enough*
cgadmin23
Hi Tony,
I have looked at the preparation instructions on the Keraquick bags which says the following:
Gypsum substartes must be dry and treated with a coat of PRIMER G . Anhydrite screeds must be dry and their surfaces must be abraded and treated with a coat of PRIMER S or PRIMER G.
Do Hardibacki Boards (on my walls) and wooden floors (22mm Ply) fall into these categories and if not can you recommend a primer that will work on the floor and walls with Mapei Keraquick.
Many thanks
Chris
Reply to Tanking area and preparation in the British & UK Tiling Forum area at TilersForums.com
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi, all I have just finished my wetroom and tanked all areas, to my understanding because this...
    Votes: 9 5.5%
    Votes: 15 9.1%
    Votes: 12 7.3%
    Votes: 49 29.7%
    Votes: 20 12.1%
    Votes: 38 23.0%
    Votes: 4 2.4%
    Votes: 21 12.7%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 3 1.8%
    Votes: 5 3.0%
