Discuss Tanking on a wet substrate in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Can a tanking membrane be used on an already wet substrate?? Will it stick?? Never used one and have little knowledge of them.
I know liquid epoxy DPM 's can but not sure if tanking membranes work the same way.
thanks in anticipation once again
Ajax123
1,213
Lincolnshire
Thought that might be the case ... Oh well back to the drawing board.
Anyone got any ideas as to how a floor that has become very wet can be retailed without lifting the height?? A long shot i know... Guarantees and warranties not required.. Just ideas....
Ajax123
1,213
Lincolnshire
It's a design fault really where a drain has been put under a work top for emptying buckets and of course the result is the jackets get emptied onto the tiles and the water swept into the drain. Add to this that the tap used to fill the buckets is not over the drain either you have lots of water pretty much permanently on the floor. No tanking or water proof grout were used with the result that the whole floor has become saturated. It's a major issue as the area is in an operational kitchen and to repair it will mean shutting the kitchen down which is a non starter. The area was never supposed to be a wet room so was not designed to cope with the amount of water it is getting.... Nightmare.....
Reply to Tanking on a wet substrate in the Canada Tile Advice area at TilersForums.com
  • Sticky
Hi, trying to find my way around this question. We had a new bathroom built, it was...
Hello, i hope someone can give me some advice please. I’m planning on tiling our bathroom walls...
Ajax123
Lincolnshire
Website
https://www.lkabminerals.com/en/products/gypsol/
What member type are you?
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
