Discuss Tanking onto Hardiebacker or Tilebacker in the Canada Tile Advice area at TilersForums.com.
Plumbing Tiler
Hi All, just a quick question?, in say, for example a domestic bath/shower room would you still tank the walls when you have installed Hardiebacker or Gypsum Tilebacker board onto the studwork or do you only tank when installing onto normal plasterboard where replacement isn't an option?
Thanks in advance everyone!
Plumbing Tiler
Hardie is only water resistant not waterproof, so tanking is advised.
Thanks Whitebeam, I was aware of that but was just thinking that as it claims to be rot proof, swell proof, crack proof, warp proof and has mould block built in, and then the tiles are installed using a cement based addy then how much damage can water actually do to it?, is it therefore a waste of time to replace standard plasterboard in wet areas and better just to tank instead?
Reply to Tanking onto Hardiebacker or Tilebacker in the Canada Tile Advice area at TilersForums.com
Hi everyone, I'm looking for some advice on final floor buildup. We're installing a shower tray...
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
I'm looking for some expert advice and hopefully some reassurance.... I've just had a complete...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
