Discuss Tanking required over SLC for Travertine (not wet room) ? in the Canada Tile Advice area at TilersForums.com.
I
Indiansandstone
Hi to all at TF - seems like a friendly place!
New ensuite has enclosed shower so the 2sqm of trav should not be subject to water continuously except for wet feet etc... The SLC is over elec UFH, over 10mm marmox (glued and screwed) boards to 18mm WBP ply at 200mm centres onto noggin'd and shuttered joists (passes the water glass jump test and I'm 16st!)
I read a thread recommending tanking or even Ditra specifically to protect the SLC from moisture ingress (its Mapai Ultraplan Renovation). Is this really recommended or required?
Also I'm planning to bed with a white one part powder rapid set flexi - would ideally minimise the depth of adhesive to 5-6mm, is this realistic with a solid bed trowel? (they all seem to be 10mm depth?)
Thanks!
I
Indiansandstone
Thanks for the reply - am trying to minimise the height due to how close its getting to the low profile try.... (good planning!! :thumbsdown: )
So what depth of addy woud you say is needed under the ditra, and can i get away with a tilting my trowel to get a thinner solid bed above it?
PS I'm assuming i need to cycle the UFH up gradually once before tiling over as well...
Reply to Tanking required over SLC for Travertine (not wet room) ? in the Canada Tile Advice area at TilersForums.com
H
Any help or suggestions would be greatly appreciated. We are renovating our house and a year ago...
16K
mache
Evening chaps.. Run a small company installing kitchens and bathrooms & have been asked to tile...
Looking for a bit of advice re wetroom installation. I have completed a few wet rooms and have...
Hello all, I am a tradesperson but do not know a great deal about tanking for a wet room -I've...
Here's a little one we did earlier this year. All designed, supplied and installed by us. This...
10K
Colour Republic
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
