Discuss Tap holes in the UK Tiling Forum area at TilersForums.com.
macten
1,158
Nottingham
As above.
I always mask the area off, not for a neater cut, but so you can mark the measurements easy.
After the first hole is done I always check that my 2nd measurement hasn't slightly changed by standing the tap in place.
Richard Edwards
A couple or four of tips -
[1] measure twice and cut once, if in doubt measure again
[2] Always drill a small pilot hole in Acrylic first
[3] Always use the smallest hole saw you can for the o/d of the tap threads - ie if you need a 22mm hole, don't use a 25mm as its all you have, go out and get a 22mm
[4] Always use sharp drills and sharp bimetal hole saws, blunt old tatty drill and saws will burn and slip laterally and create an elipitical hole.
Hope this helps
Reply to Tap holes in the UK Tiling Forum area at TilersForums.com
  • Sticky
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Hi, I am in the process of tiling with subways and just wanted some help with corners, if trim...
Tap holes
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
