Discuss taper or not? in the British & UK Tiling Forum area at TilersForums.com.
Alan.P
OK, I'm confused, do you mean the wall meeting ceiling at point 1 or 2 in my drawing, apologies for the crudeness :D
Colour Republic
It depends on how true the line at wall to ceiling point is......some are way out of line...
I tend to finish with a trim to suit the tile...then the customer has a neat straight edge to cut to when painting..:thumbsup:
:thumbsup:this is how i do it, if the meeting of wall and ceiling is not level and true.
garretridge
if I'm reading it right, I put a back bevel on tiles with my wet saw, so the face of the tile is longer than the back of the tile. Or do you mean the wall/ceiling measuremment is longer at one end than the other?
cheers think i will have a go at that be nice finish if done right all else fails then trim it is thanks guys !:thumbsup:
L
Leatherface
The way I would do it for a ceiling slope that has an angle is :
Place a straight wood batten flat, on the row of tiles below the top row, vertical, slide up to ceiling height. Make a mark on batten where it crosses the tile, transfer to tile you front of tile want to cut, make mark and add extra for grout line. Repeat other side.
You now have depth of cut for front of tile.
On the back reduce the height of the marks by the thickness of a tile.
Draw a line from each mark to other on front and back.
Use angle grinder to cut at an angle following the lines....
hey presto should fit perfectly.
If in doubt cut a little to big, then offer up.... Check and re trim until best fit is acheived
Hope this makes sense :thumbsup:
This ceiling had an unusual slope from side to side and upwards.....
Notice, tiles tight up to ceiling
Reply to taper or not? in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hey. I doing my first walk-in tiled shower. The shower is 4’x8’. Most of the floor is covered...
taper or not?
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
