Discuss Terracotta tiles in the British & UK Tiling Forum area at TilersForums.com.
Cafourques
Has anyone any experience with new terracotta tiles (tomettes)? i have laid a new floor and impregnted them with a mix of linseed oil and turpentine. I wondered how long I should leave them before waxing. Any ideas? The quicker the better as I need to use the floor as it takes me from the kitchen to the dining room!
Thankyou.
Cafourques
did you wipe the access off ? not shiny is it ? where did they come from ?
Yes I did wipe off the excess and they came from a local tuilerie here where I live in SW France. They are hand made and we feel very privelidged to have them!
Will post photos when it is finished - which may be a while!!
DHTiling
4 coats unless they are mex carillo then oil wont do anything but soak through but haven't seen them for years no good using oil on them
Enlighten us then pete.. boiled linseed thinned and applied to saturation and buffed off before drying isn't the way then.?. must be a terracotta i have not seen or used then... but saying that a lot of years since i used boiled linseed oil and bri-wax.... modern methods for me nowadays..
Cafourques
I haven't seen any tiles French tiles called "tomettes" before, but I did lay some porcelain tiles from Thailand last week. You know the sort, the extra special quality ones, from the Tourettes range...:incazzato:
Tomettes is the local name for hand made terracotta tiles.
Reply to Terracotta tiles in the British & UK Tiling Forum area at TilersForums.com
Hi there. Wondering if anyone can help? We had a path laid using reclaimed quarry tiles on top...
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
Terracotta tiles
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
