Discuss Thickness behind tiles to be left? in the Canada Tile Advice area at TilersForums.com.
Just taken on my first job, previously done heating and plumbing but wanted to tackle full bathrooms and build up my knowledge.
Everything is going pretty good so far I just wanted advice on the gaps between walls. Now my main & largest wall opposite the doorway which is to be tiled parallel to the bath long ways I was wondering what size in mm to leave each side. I know it is 6mm for movement but I am thinking I need the tiles on the side walls to slide behind and considering the following factors I am thinking around 16mm each side
I am using 8mm ceramic tiles therefore, 8mm either side, 3-4mm thick adhesive for the tiles & 2mm spacer, 2mm for give/take factor so providing I leave 6mm off the back of the wall for my side tile I was thinking 8+4+2+2 so around 16mm could anyone further advise?
Thanks in advance
Reply to Thickness behind tiles to be left? in the Canada Tile Advice area at TilersForums.com
Newcastle
What member type are you?
  1. Bathroom Fitter
Business Name
None
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
