Discuss Thickness of WEDI backerboard in the British & UK Tiling Forum area at TilersForums.com.
It is not plasterboard but plaster on brick.
You will be fine to remove the plaster and dot n dab plasterboard to the wall using plasterboard adhesive.
It will be approaching the safe limits for that weight of tile on to plaster as you need to add the weight of adhesive and grout to it as well. Plaster will only accept 20kg/m2!It is not plasterboard but plaster on brick.
Hi ya,
Just for your information the thermal construction boards we sell will take loads up to 86kg/m2 and in tests done the adhesive failed and not the board!!
Can you get me some info on that weight capacity Aaron....thats an awful lot of weight holding for a cement board...40kg to 45kg but 86kg...:yikes:...lordy thats alot...
So can you pm me some info stating that is so..please..
Thats a good price for those panels, only problem is I live in France. Not sure if you will deliver there:smilewinkgrin:
If I decide to go down the backerboard route does anyone know if I will get away with the 6mm ones using adhesive over the whole back to adhere to the brickwork?
Reply to Thickness of WEDI backerboard in the British & UK Tiling Forum area at TilersForums.com
