Discuss Thinset over faucet valve - unpleasant surprise in the America Tile Forum / Advice Board area at TilersForums.com.
Douger
U.S
Not confident there is a convenient fix to this particular problem. In a tiled shower/bathtub, I have leaking faucet, I removed handle and related fixture. Then discovered that previous owner (or sloppy plumber or sloppy tiler) somehow covered access to valve with Thinset (mortar). There's mortar on the brass valve, too. Obviously difficult to identify the valve or cartridge that needs to be replaced. Does anybody know a delicate way to remove Thinset? It's a small area.
Not confident there is a convenient fix to this particular problem. In a tiled shower/bathtub, I have leaking faucet, I removed handle and related fixture. Then discovered that previous owner (or sloppy plumber or sloppy tiler) somehow covered access to valve with Thinset (mortar). There's mortar on the brass valve, too. Obviously difficult to identify the valve or cartridge that needs to be replaced. Does anybody know a delicate way to remove Thinset? It's a small area.Roof Repair Alexandria Va
For removing Thinset around a covered valve, try a handheld oscillating tool with a grout removal attachment. It's precise and allows for careful work to avoid damage. Slow and steady does it. If you're not comfortable, consider calling a professional to help identify and replace the valve or cartridge. Good luck!
Reply to Thinset over faucet valve - unpleasant surprise in the America Tile Forum / Advice Board area at TilersForums.com
Expert advice for professional installers on drilling porcelain tiles. By Richard Hazell of 365...
6K
jamesy07
USA Tile Forum Popular
America Tile Advice Trending
U.S
What member type are you?
  1. Homeowner
Business Name
Dugger Properties LLC
Tags
over
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
