Thoughts on this set up Discussion ThreadThoughts on this set up Electrical Advice
This is supplying a small commercial set up. SWA is only 16mm and the isolator is rated at 100A. Earth cable between MET and SWA is only 10mm.
How would you code it? Having a brain fart and thought I'd seek other opinions.
Thoughts on this set up for the original thread on Electricians Forums
