rawdon51
Hi All,
Have had our hallway tiled, which leads off onto several other rooms that are a combination of wooden laminate & carpet covering.
This has expectedly resulted in a few different threshold challenges to be overcome. First, the tiling finishes at a different height to the other floor coverings, so we obviously need some sort of transition strips. Second, and a bit more challenging maybe (?) the tiled surface on one of the joins (to the laminate) also lays at a slight angle....i.e. the laminate and tile surfaces are not horizontally parallel.
Ideally as we have a lot of white oak features (doors, staircase etc.) and white oak effect laminate, we'd like transition profiles to match.
Has anyone come across this type of challenge? Does anyone have any links to companies online selling maybe bespoke profiles of some kind, or is a local joiners the best bet?
Thanks. Jon.
Thanks. Jon.
