• Thread starter Chris Pink
  • Start date
  • Replies 0
  • Views 69
Discuss Tightening galvanised pipe and fittings Discussion Thread in the Plumbing Advice area at TilersForums.com.
I have a threaded galvanised tube between 2 T-pieces. I can’t screw the t-pieces onto the tube - they’re already sealed to the spur. So the only way I can screw the pipe between them is to screw it all the way into one side then screw it halfway into the other (by unscrewing from the first end) . So neither is tight.
How do I seal this? I can see that I can use enough PTFE tape on the 2nd end but by un tightening the first end halfway won’t I destroy that seal?
What’s the proper way to do this? I have three tubes in my setup to do this to.
Tightening galvanised pipe and fittings for the original thread on Plumbers Forums
Reply to Tightening galvanised pipe and fittings Discussion Thread in the Plumbing Advice area at TilersForums.com
TF Group Please Join
Plumbing Advice
Tags
None
