Discuss Best Tile Adhesive and Grout for Outside in the Tile Adhesive and Grout Advice area at TilersForums.com.
Status
Not open for further replies.
DHTiling
Which Tile Adhesive Did You Use Most During 2011?
Please vote on the Poll. All answers can be seen by the members.
If you used a brand not showing then please respond with the make.
Best Tile Adhesive Brand in 2011: Whats the best Wall / Floor Tile Adhesive Make? This is the Annual Tile Adhesive Poll by TilersForums.com Members. At this point we had 93,574 Members voting on the best tile adhesive brand for walls or floors (as it was cement-based we are voting on which can be used for either).
I'm talking about both cement-based and dispersion. And I'm asking which brand in general did you use the most?
It might be due to trust, availability, customer preference, whatever. Just if you totted up the lot you used, which one did you use and buy the most of ?...
VOTING IS NOW CLOSED​
183 Votes in total | Winner was Mapei​
This is for 2011 only
The following is the best tile adhesive poll for 2007
The following is for 2008
2009 poll for best tile adhesive is here
The best tile adhesive brand for 2010
The best wall tile adhesive for 2011
The best floor tile adhesive for 2012
Best tile adhesive make for 2013
Best tile adhesive manufacturer for 2015
There was a huge gap for a few years where we didn't do annual polls, so the next poll is from 2016 to 2021 hence the large response​
You can see the results changed quite a bit for the next poll we did.
ALL TILE ADHESIVE POLLS - WHICH TILE ADHESIVE BRAND DO YOU USE THE MOST?
Andy Allen
1,318
Gloucester
weber for me....
Best Tile Adhesive Brand in 2011: Whats the best Wall / Floor Tile Adhesive Make? This is the Annual Tile Adhesive Poll by TilersForums.com Members. At this point we had 93,574 Members voting on the best tile adhesive brand for walls or floors (as it was cement-based we are voting on which can be used for either). Best Tile Adhesive and Grout for Outside
Status
Reply to Best Tile Adhesive and Grout for Outside in the Tile Adhesive and Grout Advice area at TilersForums.com
  • Sticky
  • Poll
Which Tile Adhesive and grout brand did you use the most in the last 12 months? And also...
7K
This is the Number 1 Best Tile Adhesive from 2007 to 2021 recorded (almost) annually Discussion...
10 minutes ago Add bookmark #1 Which mapei adhesive ( it's convenient for me to buy this...
  • Locked
Which tile adhesive have you most used during over the past few years and ending in 2021? ALL...
6K
We had our kitchen floor tiled in large plank-style porcelain tiles (90cm x 15cm) about 2 years...
Tile Adhesive Trending Topics
Status
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
