Discuss Tile backer board, which brand do you recommend? in the Tanking and Wetrooms area at TilersForums.com.
Andyman
98
Wales
Hi guys
I am in the process of bathroom refurb.
I have around 23m2 of walls to tile approx 50 percent to new stud and 50 percent to rendered wall which I may counter batten.
Stud walls I want to either use a thicker board or insulate as they are external.
Floor will have 6mm boards for electric underfloor heating .
What brand would you choose and in the drier areas would you use mr plasterboard?
Boggs
1,118
Uk
In wetrooms I use Deltaboard, but in bathrooms/shower-rooms I just use m/r plasterboard and tape and tank the wet areas.
Waluigi
Providing the weight of the tiles is under the 32kg PSM threshold then I wouldn’t hesitate using a combination of PU Foam and plasterboard on the studs. It’s all I use now on studs and the walls become perfectly flat and Plumb. Screw through the plasterboard once the foam has set which is under an hour.
Using foam for block walls is also possible but it takes a good amount of practise to get the wall perfect and I wouldn’t recommend it. It’s not easy. I’d recommend conventional gypsum based dri-wall adhesive.
Waluigi
Foam is able to stick studs to a wall but in this instance I was talking about a stud wall with the old plasterboard removed. The bare studs are then sprayed and then the new plasterboard is bonded on to them. Then screwed.
This is talking about bathroom walls which are rarely very big. If you have say a 6 metre long wall that needs making true then I’d look into other ways of getting it flat and Plumb. That’s another thread :)
Boggs
1,118
Uk
This is a curiosity question but what’s the benefit of using the foam on studs if you are screwing anyway?
Reply to Tile backer board, which brand do you recommend? in the Tanking and Wetrooms area at TilersForums.com
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
Wales
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
