Guest viewing is limited
Tiling Tool Suppliers
Discuss Tile Cutter hire for 60cm x 60cm Porcelain tiles ????? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
jcoles7
Hi All,
My first post so be gentle.
I am going to be tilling our wet room and have some 60cm x 60cm Porcelain tiles that are 10mm thick. I have used a Plasplugs pro tiler (black plastic one) before on 30 * 60 tiles and they were difficult to cut and the cuts were chipped in places. This time I want to have perfect cuts and realise I need a much more powerful tool and ideally I think I need to hire a saw bench.
Travis and HSS seem to do Tile saw bench are these any good ?
Any advise appreciated.
Best Regards
Jason
jcoles7
Hi Dave,
All of the cuts I need to do are straight cuts, no L shaped cuts. Would I be able to do all the cuts for the Linearflo (see pic below) with the "Big Clinker" ??
If not and would also need to hire a wet saw I may as well just hire that rather than buying the dry cutter too.
What do you think ?
I assume that the reason I had chipping previously was due to the saw being under powered for the job. Also on these large tile saw benches the tile stays still and the cutter moves on rails from what I can see.
Best Regards
Jason
Reply to Tile Cutter hire for 60cm x 60cm Porcelain tiles ????? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
I need a tile cutter gor 600x600 Italian porcelain and am close to pulling the trigger on the...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Popular Tile Cutter Threads
    Votes: 5 5.7%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 22 25.3%
    Votes: 13 14.9%
    Votes: 27 31.0%
    Votes: 3 3.4%
    Votes: 2 2.3%
    Votes: 18 20.7%
    Votes: 14 16.1%
    Votes: 6 6.9%
    Votes: 5 5.7%
    Votes: 3 3.4%
