Discuss Tile cutting.... in the America Tile Forum / Advice Board area at TilersForums.com.
Hi, i need to trim some 600x300 porcelin tiles, i need to take about 5mm max off of the 300 side....
Would a manual cutter do this?? Or best to use my wet cutter??
Only issue i have with the cutter is the bed isnt really wide enough to fully support the tile....
Any thougts or advice grestfully received...
judge
1,078
If you have a grinder with good blade why don't you try scoring the tile with the cutter then carefully grind the edge ?finish off by using a diamond polishing block(
200 grit roughly)
Reply to Tile cutting.... in the America Tile Forum / Advice Board area at TilersForums.com
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
USA Tile Forum Popular
America Tile Advice Trending
somerset
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Aerospace Industry
Tile cutting....
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
