Discuss tile drilling in the UK Tiling Forum area at TilersForums.com.
davey-j
I'm on a bathroom which i have dry lined(dot and dab only) on all walls.The question is,if im drilling tiles (365 drilll bits) to put up a mirror and shelf how do i get the wall plug to fit snug in the wall in the brick?
I drill the hole in the tile with the correct 365 drill piece through the tile and through the plaster board,then i get a drill bit and drill into the brick........yes so far? how do i get the wall plug into the wall through the tile into the wall behind so that i can get a screw to fit in? Im sorry if im sounding a bit bone, am i going along the right lines or am i way off, thanks guys
Colour Republic
put the rawl plug on the screw first (just 2 or 3 turns) then feed it through the hole until its in the wall, tap the screw lightly with a hammer until you feel rawl plug has sunk home.
I then take the screw out and put a second rawl plug in the hole so it sits in the plasterboard. Then fix up the mirror... or whatever else it might be
Deleted member 1779
Yes its right. Depending on the substrate behind may mean swapping drills.
The thing to remember here is that the drill WILL WORK in any material behind the tile
(Wood, Plaster, Brick, Stone, Backerboard) BUT it will gum up the barrel. More drills are blown drilling deep behind tiles than are blown due to wear and tare.
Its better to stop and pop out the core / plug than to continue. Compacted plasterboard is a bugger to get out of the cores so avoid if at all possible.
More small drills are lost to having their barrels gummed up with plasterboard than lost to wear and tear. At the point of breakout from the tile - stop.
The white substance in hole B is actually the plasterboard.
This is the enemy of small tile drills at 6mm and 8mm. If you can... Swap drills.
Deleted member 1779
To new post readers just be aware that...
If you want to be 100% sure of drilling any tile then we do the rawl plug packs: EG: 8mmx4
£29.99 for a pack of four
x 8mm drills PLUS the anti-slip guide plate. P&P = £2.99
This is price compared to Screwfix which sell them at £10.27 each so would cost you £41.08 plus £5pp if your order is less than £50.
SAVINGS: The savings per pack of four would be £13.01 if you buy from us as the four pack. In addition we also include the anti-slip guide plate - vital - to stop skidding on those new tiles. This option is not available from SFD. However they do provide alternative guides but these will cost you more money.
If you are trade and looking for bulk discounts then contact us and we can offer even keener pricing on volumes.
The anti-slip plate is vital to stop your drills slipping on those tiles.
Deleted member 1779
There is a bit of a knack (and some do's and donts)
The main thing is to try and drill out only the tile and nothing else behind. The core should pop out with gentle persuasion from the core ejection slots we provide in every size bit.
Dont drill into tile adhesive, plasterboard because this tends to gum up the barrel of the smaller drill bits (6mm and 8mm). The soft material seems to compress in the barrel if you try to force it back out. That leads to difficult ejection.
Each holesaw is fitted with core ejection sockets
To remove a core use an allen key to poke out the tile
Larger cores have more areas available for access.
You will often find that the fixures and fittings you are installing are supplied with allen keys. Useful for getting into diamond drill cores.
Do try to drill ONLY the tile and not beyond
Try not to break the plug during drilling. If you snap it off at 90% drilled then the plug can rotate in a 6mm drill. This makes it tricky to pop.
Try not to drill anything other than tiles. Softer material gums up the internal barrel.
Hint: If you give up and are stuck with a piece of tile inside a core then you may want to abandon the poke out. Just push it to the back of the barrel. Use that core to "start" holes and swap over to clear barrel cores. Also you can stack the cores inside the barrel of a drill about four or five times depending on tile depth.
Reply to tile drilling in the UK Tiling Forum area at TilersForums.com
Hey everyone. Hope you are well. I want to learn how to tile and do a fairly basic bit of...
tile drilling
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
