Discuss Tile on tile in the UK Tiling Forum area at TilersForums.com.
Paul J
Uk
Hi. Hoping you al. Can help me.
I have an issue where I had a bathroom built and a shower installed. The shower is tiled floor to ceiling on three walls with a shower screen on the 4th side.
I had issues with the tiles that the fitter installed ( he has since disappeared so I can’t go to him to resolve ) and I thought I’d try to do the bits myself.
Anyway The grouting in the tiles is weak and in places has gone leaving gaps between the tiles. I have dug out as much as I can and regrouted Not my issue is the alcove he built and tiled The base of the shelf is angled backwards leaving water pooling at the rear of the shelf. I think I have a solution without ripping all the tiles out I was going to lay another cut tile ( with an insert to raise the back so the water drains out ) but my question is. Can I tile on tile in the recess or do I have to prep the base tile and if I do need to prep it could anyone let me know how and with what These are very glossy porcelain tiles
send pictures
Paul J
Uk
I think you have a bigger problem if grout is falling out. Is there any movement in the tiles ?
No. There’s no movement at all thank god and they are heavy tiles. I think it’s the way the adhesive was applied when fitting the tiles but I hope that I don’t have to start from scratch. So for now I am doing what I can to stop the leak.
Could stick the new tile with silicone or similar over the old to wing it , tile adhesive does stick to glaze but is not really bonded , could scruff the tile to be covered with the grinder if want better bond to old tile face
Reply to Tile on tile in the UK Tiling Forum area at TilersForums.com
I applied Lithotin stainstop to my newly installed sandstone tiles. Shortly after i had an issue...
Tilers Forums on FB
