Discuss Tile onto ply wood. in the Canada Tile Advice area at TilersForums.com.
Radiantpaper
Hi
Ok the misses wants the kitchen done. So went out and got paint tiles etc. I now discover there was a door in kitchen that has been boarded up with ply wood after removing some tiles. Lining paper then ply wood. Good eh. Its only a small area about 30cm x 60cm.
I am using Bal green star already got it. The tiles are the ceramic brick type. Can i fix to the ply as the other tiles were there and its a small area?
No thats the area that was covered with tiles. If i replace with plaseter boards means ripping out the kitchen cuboards etc?
That's a small door,
if the area which has been boarded has a unit attached then yes the applicable cupboards will have to come off.
As far as tiling onto any ply substrate I don't recommend it.
If you do ahead with the ply substrate make sure the wood is free of all paint/old adhesive etc then (As Cam Low said) prime prior to tiling.
Reply to Tile onto ply wood. in the Canada Tile Advice area at TilersForums.com
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
Tile onto ply wood.
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
