Discuss Tile removal in the UK Tiling Forum area at TilersForums.com.
CJ CERAMICS
hiring a breaker as per the advice above is always a good option or alternativley you can always buy a sds drill to keep and use in the future ShowImage.jpg something of this nature is a reasonable sds drill at a good price......you will ofcourse have to buy the drill bit for it as well.
hope this helps
chris
terrygrant
A pnumatic drill with rotostop fitted with a scutch chisel bit like this one from screwfix 50887
http://www.*************/prods/5088...lus-Chisels/Armeg-SDS-Plus-Scutch-Comb-Chisel
or if you dont want to spend that much I find these work really well
http://www.*************/prods/5986...DS-Plus-Wood-Chisels/SDS-Wood-Chisel-Set-5Pcs (dont but the really cheap ones they do though as they simply snap at the shaft.)
I find they work much better than the standard chiseling tips because they can deliver the blow to the junction between the tile and the bed very precisely resulting in a much higher sucess rate in removing tiles and leaving backing in place. You do have to keep resharpening the tip though.
Of course the easiest way to remove these tiles is to get someone else to do it for you :)
Good luck
Terry
Reply to Tile removal in the UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
HELP! I'm really hoping someone might be able to give me some advice..... our cleaner just used...
Tile removal
