Discuss Tile Runout in the British & UK Tiling Forum area at TilersForums.com.
Monty_GB
Hi,
Please excuse my inexperience, i'm part tiling a friends bathroom, corner shower with 405mm x 405mm Travertine tiles(eek).:surrender:
I've marked the position of the tiles on the wall, vertical and horizontal and have found the tiles(where they meet in the corner) to runout by the top of the shower , by about 1-1.5 inch.
The only solution i can think of is to fit level batons midway and tile up from here, then to tile down cutting the corner tiles to fit.
Is this the correct way to do it?
Is there any other solution?
Any advice greatly appreciated
I feel as if i've bitten off more than i can chew, but i really want to learn.:6:
GatesheadCol
Just a quick thought Monty, did you 'flip' your level when going around the room?? most spirit levels have a 1 or 2 mm discrepancy so when your drawing a horizontal line round the room you should flip your level over each time if you get what I mean?
That way any discrepancy in the bubble will even itself out. If not that 1 or 2mm could become 15-20mm by the time you get all the way round
although as said by others its hard to grasp what your actually meaning with this one TBH
Monty_GB
Sorry for not replying sooner, tried to access website but the page wouldnt show.
I'll try to explain better...
The tiles are butting up to each other, in the corner of a shower, (corner shower unit)
if i keep the tiles level, from the floor upwards, by the time i reach midway and higher, there is a gap between the butted up corner tiles, of about 1-1.5 inch, due to the wall not being level.
I used a level for the horizontal and a plumb line for vertical, i didnt flip the level so will double check
Thanks for everyones replies so far, sorry enduro for not ringing, thanks for the offer of help.:thumbsup:
If the tile marks are correct...
Is there a way to keep the full tiles even, all the way to the top?
Would putting a baton midway and tiling up from there, then cut the tiles below the baton to fit the corner work?
Or is there another way to acheive even and level tiles on such an uneven wall?
Gazzer
If i am reading this correct ther is only 1 practical way to do this and that is to start by placing a mark of the chosen cut in the corner at the top and plumbing a line down. This will mean each cut coming down the wall will have to be cut at the required size ie getting smaller each time.
Thats how i am imagining your problem.
Reply to Tile Runout in the British & UK Tiling Forum area at TilersForums.com
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
  • Sticky
6K
Runang89
Tile Runout
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
