Discuss Tile spacers. in the British & UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
I used to remove them during tiling. So i'd tile to a height around the room, or on one wall, and then as I tile above that I'd nab the spacers from the first few square meters and re-use them on the next few.
Though that'll work with ceramics, and on floors using any tile, you might find you need to keep using them while the adhesive goes off if you're using heavy tiles, or large ones. And those are being fitted a lot more now than when I used to tile.
I used to hate pulling them all out before grouting, and I'd never grout over them, there's always one or two that cause big problems or you chip tile edges trying to force them out with something. So I got used to waiting for the adhesive to go off enough to carry the weight of the tile and simply re-use as many as I could / would dare.
Colour Republic
Well I'm surprised you all take them out, my spacers are neigh on impossible to get out. I push them right to the back of the tile as in some cases the shoulder of a tile can be as much as 1mm front to back but is in most cases at least 0.3mm. So if i push them back I know they are sitting on the thickess part of the tile and tiles won't creep off level over a distance, this is also the reason I try to only use spacers that are well made rather than a different size front to back.
As most of you know I'm not trained but time served so apart from possible ghosting what other reasons are there for removing?
brian c
i also am aware of the different thickness's from front to back of spacer and tend not to use these spacers.The problem with these spacers is obvious..when you push them in there is a chance of slight movement and possible debonding of tile and grout line moving..well thats all i can see problematic.Each to their own.imo.
Reply to Tile spacers. in the British & UK Tiling Forum area at TilersForums.com
Hello, First post. Wish I had known about this forum several years ago. Here's my question...
Tile spacers.
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
