Discuss tile spacing in the British & UK Tiling Forum area at TilersForums.com.
L
Leatherface
2 or 3 mm. Have a good look at the tiles though !
If you use a long leg spacer and push it right to then back of the tile you may end up with a wider space than your spacer !!! This is because some tiles are slightly deeper and wider at the back edges than at the front. Hence a 2mm spacer pushed in from the front can sometimes end up looking like a 3mm when grouted !!!!!!
sometimes not really noticeable initially unless you measure !!
davy_G
Same here 2mm/3mm on walls and 3mm on floors, think you need a min of 3mm on floors to enable the flexi grout to work,I am sure someone will confirm this as i am not 100%.
Gary
Maybe im wrong here as well but is Building regs or BS not minimum of 3mm on floors? Ive done a few jobs with rectified 600's with 2mm at clients request/risk. Looks class mind you
Reply to tile spacing in the British & UK Tiling Forum area at TilersForums.com
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
tile spacing
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
