jubba
I am just doing our bathroom and came here for advice but have ended up even more confused?
I need to repair a wall (outer brick) that is damaged ready for tiling, The plasterer is coming Friday and has advised to repair with bonding coat then seal with PVA!
After reading info on this site I now understand that tiling to a PVA'd surface is a big no-no. (great thread on PVA vs Primer by the way)
So what I need to know is can the bonding coat be sealed with proper tile primer, then tile to this or have these surfaces got to be skimmed prior to tiling?
Is there an alternative to bonding coat that can be used to repair walls then tile to?
