Discuss Tile Trim for Limestone? in the British & UK Tiling Forum area at TilersForums.com.
bigneil
that is totally down to your personal taste as to what is more esthetically pleasing, i personally don't like any of the plastic trims with it and i have never put chrome trims with it. i did once used a metal trim that was enameled with a colour called "soft cream jasmine" or "cream" to any normal person, it looked smart with travertine
Grace'sDad
Take the edge off with a small mitre cut. I prefer about 1/3 of the tile width. Not using a trim means you must be very accurate, but the end result looks so much better!
If you don't have a saw which can do a consistent clean mitre / bullnose, you could always file down the edge after fixing, using a diamond file or even better a dremel with a diamond tip. (but don't slip with the Dremel!)
MICK the Tiler
I've used all the methods mentioned above over the years, trim , mitre, profile cut, etc but for me, a plain well constructed butt joint with the edge honed to remove all saw marks still looks the best IMO. I use hand diamond stones for honeing edges but with limestone various grades of sandpaper wrapped around a timber block will suffice.
Reply to Tile Trim for Limestone? in the British & UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
