Guest viewing is limited
Discuss tile trim for sharp curved corner on bathframe in the UK Tiling Forum area at TilersForums.com.
ger ol
I'm tiling a bath frame (bath box) and triming the edges with chome/stainless steel trim. One of the corners is rounded but its a bit too sharp for normal curvable tile trim. Does anyone know where I can get tile trim that will bend to a sharper curve?
Just to explain the curve, if you stand over the bathframe corner and look down at it from above, place the top of a coke bottle on the corner so that it is touching the two edges at either side (at 90 deg angle to each other), the curve on the corner is pretty much the same as the curve on the coke bottle top.
any help much appreciated!
thanks
Ger
DHTiling
thanks
Ger
You need to activate your account.. you should have an activation email.. click the return link..
ger ol
HI there lads! thanks very much for the replies, its taken me ages cos I couldnt log in till now. OK so you reckon thats the best way to go?
Ok well Ill try that then. I thought that there might have been a specialist tile trim on the market that would allow me to bend it to any shape. Ive tried bending the chrome tile trim already and it tends to dent and not bend smoothly because the curve is a but sharp. But I guess if that's what you suggest as the best way to go then I'll have to try make it work.
Ger
paulyoung666
Ger
can you not clamp it and bend it round a former to achive a nice tight corner :)
Perry
Ger
use the stainless trim its more malleable :pete
Brass or aluminum will fracture
Never had that problem myself:smilewinkgrin:
http://www.*******************/tile-trim-tools/1097/Forming Machine
http://www.*******************/images/Forming%20Machine.jpg
http://www.*******************/tile-trim-products/177/formable-metal-tile-trim
http://www.*******************/images/EFA-m.jpg
Perry
Tile Trim Forming (Bending) Machine 777 For Hire - £340.00 - www.protiletrim.co.uk
Formable Metal Tile Trim from www.*******************
wasn't having a go engineer by trade and thats cheating :lol::lol:
Reply to tile trim for sharp curved corner on bathframe in the UK Tiling Forum area at TilersForums.com
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Wondering what the options (and fashions) are for edging. Particularly outside corner edges...
Hi all, Apologies if this has already been answered elsewhere. I am tiling the outside of my...
rufus the tiler
A bit of an odd question I'm guessing. I have a floor that needs tiling, the existing...
18K
Italy
I
I'm tiling (9mm) over cement board (12.5mm) around a bath and the board/ tiling will be 1200mm...
10K
WharncliffeSteve
