Discuss Tile trims and tile spacers in the UK Tiling Forum area at TilersForums.com.
Tilestiles
Walls 2-3mm spacers. Floor 4-5mm spacers. Depends on tiles though. If doing floor with a sheer edge to tile (eg. marble, porcelain etc) then would use 2mm on floor also. Most trims come in either 6mm, 9mm or 12mm so best to match the trim to the tile. If tiles are 6.5mm wouldnt recommend 6mm trim as it will lok daft. Go to next size up (9mm) as when adhesive behind 6.5mm tile it will be more like 8.5mm thick so 9mm trim would look better
Proper Job
you might find 7mm trim a little thin, you have to take in to account the bed thickness of your adhesive it should be or recommended by weber 6mm in dry areas and 8 mm in wet areas but when tiling around windows which are hardly ever plumb or level you find yourself packing out a little so i would recommend 8 -9mm mate. If your using tile over trim which covers the cut edge you may find 7mm way to small.
Reply to Tile trims and tile spacers in the UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, First post. Wish I had known about this forum several years ago. Here's my question...
Hello one and all, I have a 240m2 floor tiling job to price, including a tile upstand edged with...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
