sarahb082
Hi
Our tiler has finished tiling in our cloakroom however the position of the door bar is bugging me and I was hoping to get some advice on whether I should pick him up on again or not.
The cloakroom door opens outwards into the hallway. The tiler has left the thin door bar (currently situated directly under the door) in place. The door bar still is connected to the carpet in the hall and then the other side is about a 5mm gap before the tiles start. We are getting the hallway covered with laminate so will be getting a new door bar however, due to where the tiler has finished the tiles, I think that when you are in the cloakroom toilet and the door is shut, you will see most of the metal door bar, as the tiler didn't lift the existing door bar, and tile up to it.
Should he have done?
Should we get him to re-tile this section?
Also, one tile near the wall had a chip in it just off the edge and the sealant would need to be a very thick line to cover it (tiler is coming back on Wed to seal). Should we expect him to replace this tile as well? We originally thought it was just grouting and would wash off!
Thanks!
Thanks!
