Discuss Tilers keep recommending ready-mix adhesive in the Tile Adhesive and Grout Advice area at TilersForums.com.
jtg90
Hi All,
I have had several tilers quote for tiling our bathroom using 100x300x8mm ceramic tiles + some areas with 200x200x8mm patterned ceramic tiles. This includes tiling inside a tanked shower cubicle (with pumped shower). All the tilers so far have said they will use tubbed ready-mix adhesive.
This surprised me because reading this forum and others - most people seem to recommend a powder adhesive.
One of the cubicle is a ~2m 'wing wall' i.e. only supported on one side and at the floor (doesn't go all the way to the ceiling. It is well secured to the wall and floor so there is hardly any movement but if you hit it hard the top corner will vibrate slightly - I mentioned this to each of the tilers too, thinking a flexible adhesive would be best but they still each said it would be fine with basic ready-mix adhesive.
Is ready-mix ok in this situation given that they are only small tiles or should I insist on using a powder adhesive e.g. Keraflex?
It's only quite a small job (about 10 m2) so maybe they feel it's not worth mixing up powder adhesive for this size job??
Any advice would be great.
man of kent
I want to sleep at night and want to go on holiday without fear of phone ring with people saying there are tiles coming loose. Why whould you not use only the best adhesive?
You're so right Bathfix Bob, maybe there are lazy tilers out there who either don't know how to mix a good quality cement based adhesive or they don't mind paying for the manufacturer to put the 'lubricant' to help apply in the material in at a cost dearer than water???
Reply to Tilers keep recommending ready-mix adhesive in the Tile Adhesive and Grout Advice area at TilersForums.com
    • Agree
    • Informative
Is the issue with ready mixed adhesive seemingly only recommended for 30x30 tiles max that it...
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
Tile Adhesive Trending Topics
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
