Discuss Tiles and adhesive for electric UFH in the British & UK Tiling Forum area at TilersForums.com.
U
Uheat
Hi Bob,
Firstly if you ar eplanning on going straight onto the plywood, European standard IEC335/EN60335
recommends for safety that no more than 100W/m2 is installed directly on a timber floor and only giving you a 'Warm Floor' effect.
If you are wanting 'primary heating' i would recommend overboarding the ply with Insulation boards, have a look at Underfloor Heating | Floor Insulation | Uheat or if you are restricted with height use Thermopanel insulation Underfloor Heating | Floor Insulation | Uheat.
As already been recommended a flexible tile adhesive must be used. the guys on here do like Mapei stuff.
The insulation boards will be stuck down using the Flex tile adh and mechanically fixed (for security) the loose cable or cable mat should then be used. If you have not used UFH i would go with the loose cable as you can take you time with it and lay the cable where you want to.
Once the cable is down then use a self levelling compound to cover the wires, this helps protect the wires and gives a nicer tiling surface. Then use flexible tile adhesive to fix the tiles down with. Not forgetting the flexible grout!!
Please have a look at our site www.uheat.co.uk
If you let me know the details of the room i will be happy to work out all the UFH products you require.
Hope this helps.
U
Uheat
:hurray: of course its Uheat!!!!:hurray:
our cables are 3mm thick. its a duel wire cable so you only have 1 cold tail to deal with, which makes life a lot easier when fitting. All the cables and mats come with a lifetime guarantee.
you can tile straight over the cable (to save height) but most of the guys on here would tell you to use a self levelling compound over the top to help protect the cables and give you a nicer surface to tile onto.
Like i said earlier if going directly onto timber you should not be using anything higher than 100w/m2 which will only give floor warming. The thinnest insulation we do is 6mm if that helps?
Reply to Tiles and adhesive for electric UFH in the British & UK Tiling Forum area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
