Johneb
Hi all,
Following some excellent advice from you in 2012, I successfully laid approximately 40 sq m of ceramic floor tiles in our new kitchen, garden room and granny flat. All was fine for a while, but then the tiles cracked across the opening between the garden room and kitchen, a distance of slightly less than 2m. Both areas have wet underfloor heating (on separate circuits), set in approx 100mm of screed topped with levelling compound. The crack is where the two slabs of screed meet - they were laid at different times. The tiles are ceramic, 400mm sq.
Before laying the tiles, I consulted the underfloor heating manufacturer and was told there was no need for a decoupling membrane in this location - it should be fine so long as I used flexible adhesive and grout.
I have delayed replacing the tiles for over 12 months to allow for any settlement of the screed slabs and to allow the heating to be fully 'run in'. I now want to replace the cracked tiles and should be very grateful for any tips on how to lay them to minimise the risk of them cracking again
Finally, what is the best way to remove the line of old tiles without damaging those on either side? I have been told to crack them with a hammer, but again would appreciate professional advice.
Cheers, John
Cheers, John
