wrzmewallet
Hi there
The questions asked might sound dumb but at my wits end now.
Busy re tiling bathroom after stripping old out and putting in new. Tiles used are 250 x 330 mm (9.8" x 13") and 8mm thick. Adhesive is one from the local DIY giant, CeraFix Non Slip (strength to BS5980 Class B).
Put the first lot up on Friday covering an area of approx 1 sq metre. Cracked on with some other odds and ends. Came back to find tiles slowly peeling away. Thought maybe not enough butter so cleaned wall and redid using a little more adhesive. Same area. Left over night (18 hrs) and got back to said wall to fit heated towel rail. After drilling holes (not through tiles) tiles started to peel away again. What I did notice was that the adhesive was not drying, instead seemed powdery.
Tried again today and same thing happening again....blasted tiles peeling away from wall.
Could it be duff adhesive? over half tub used and no blasted tiles on wall
The wall in question is plaster board, skimmed, and tiled previuosly.
Spread on wall first the first time, on tiles the second time and today both wall and tile.
Any hints tips advice much appreciated. Thanks in advance.
Frustrated
Frustrated
