Steve G
Hi I'm new to the forum and would like some advice please. My bathroom has been dob and dab plaster boarded with 12.5mm moisture resistant plasterboard and SKIMMED. I have now sourced the tiles that I like which are 900w x 300h x 8.7mm thick ceramic, weighing with tile adhesive and grout about 25kgm2. By now you probably see my problem, the guide limit for skimmed is 20kgm2. Is there anything I can do to enable me to use these tiles without ripping down what already has been put up and starting again. The area to be covered by these tiles is a 1200 wide x 800 deep x 2400 high shower cubicle.
My questions are:
Is it possible to remove skim from plasterboard without ruining it? if so how?
I have seen on the web there is a 4mm thick tile backer board. Would it be possible to overboard with 4mm tile backer board and glue and mechanically fix through the dob and dab into the brick behind and then tile onto that. If so what do you use to glue the backer board and what mechanical fixings would you use? I have seen washers on the web.
If the above 4mm board is possible, that means the tiles and backer board will need a tile trim at each edge of at least 13/14mm to cover the edges, are they available?
Can anyone suggest another solution?
Thanks, hope someone can help.
Cheers Steve
My questions are:
Cheers Steve
