Discuss Tiling a 2 m radius circular floor - ideas? in the Canada Tile Advice area at TilersForums.com.
I am carrying out procurement for a self build house.
The staircase is circular, and my husband has drawn (CAD) a symmetrical pattern of tiles with concentric circles divided into segments, for tiling the floor of the stairwell. The radius of the stairwell is 2 meters.
If this were a patio, I could buy a kit of pre-cut stones. I cannot find anything like this in floor tiles.
Does anyone have experience of tackling anything like this? If so, do you have any practical ideas?
Frances
charlie1
I have done this very successfully with polished porcelain using an angle grinder, diamond pad. The results where as good as water jet cutting. You need to dry lay your tiles then mark off where you want to cut, (use masking tape) then with a good quality blade on your grinder. Make one continued pass 1mm deep across all the tiles (don't stop) then lift each tile and make several passes with grinder untill cut is achieved. Then dress with grinder and diamond pad
DHTiling
You can do it with any tile really , cut all tiles to size as per spec in your drawing, then dress any edges to remove the arris , i like the look of easing the edges , this will give a uniform look when grouting..
Maybe you can post a pic of the design your are wanting to achieve .. would be good to see what you have to do .
Thank you Charlie. I need that level of detail and helpful information.
Thank you Dave for your reply. I'm sorry to have to ask, but what do you mean by easing the edges? I too am in favour of a uniform look especially with porcelain.
I will see if I can get a picture too>
DHTiling
By this i mean a micro chamfer , which is common on porcelain tiles... when done right you cannot see the tile was cut ... bespoke work that looks good..
Reply to Tiling a 2 m radius circular floor - ideas? in the Canada Tile Advice area at TilersForums.com
Quick question. I have to submit a price for 600m2 of 600x600 porcelain tiles. Just found out...
11K
Tile Shop
Hi all, We recently moved into our new home and I have managed to break 2 tiles on our bathroom...
9K
Hello everyone Im still at college got about 2 months left and im about to do my very first...
rich83
11K
Rizzle from the Portizzle
L
As title says, I'm in need of a floor tiler who is very skilled. I'm in Dunstable. I have...
I
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
