Tiling a bathroom ceiling
chubbywayne44
Hi this is my first post and i was hoping someone out there could help with advice.
i am considering tiling my bathroom ceiling which is only 4 square meter. i am a joiner by trade so the problem doesnt lie there.
what i need advice on is
has any body done this before did you use plywood, plaster board,???
what adhesive what grout
what were your results.
Basically can it be done so they dont fall off:yikes:.
if so please could you give advice to a struggling chippie:thumbsup:
thank you all
wayne
yes tiling a ceiling is possible.
1. simply treat the ceiling as if it were a floor but use mechanical fixings on the tiles!!
2. ensure the ceiling joists are free from deflection..this can be a bit of a task / headache because the ceiling joists into the ceiling space are not as thick compared to your 1st floor joists! the problem will arise more when your plodding around in the loft! if you have a loft conversion then this will have a supended floor which will help.
3. add extra strength by using 25mm wbp ply to the ceiling. again, ply adds strength, backerboards have different properties.
4. overlay with a suitable backer board for a stable surface.
5. use a flexable adhesive combined with mechanical fixings
6 as jay with exoxy grout
7 . good extractor fan!! and plenty of ventilation when possible
How would you go about mechanicaly fixing those tiles mate?
at that thickness it would have to be a epoxy/resin to the rear of the tiles to adhere the fixing as chubbywayne suggested. upgrading the adhesive to an epoxy based/ swimming pool adhesive would also be a reinforcment. (belt and braces)
the fact that there will be no deflecton or weight on the new suspended ceiling will be a big plus too.
if you tile a cieling it is recomended that all tiles are epoxy wired at five points through the cieling subtrate back to a screwed anchor point, ie a joist.
it makes it a 2 man job.
obviously this is a pain to do but gives you the fail safe position should your bond fail.
Maybe tile with mosaic? Make it waterproof (proper grout) and i don't see it coming down. But I have to leave it to more experienced experts on the subject, so just a thought.
would personally avoid at all costs but can be done....
ive done one of these before (well helped scottish greg from london tiling,tile genius might i add)..... the ceiling was plyed out ready for us and we attached big sand stone tiles to the ceiling using plenty of ardex adhesive. And drilled into the tile and mechanically fixed brackets on them using a 2 part liquid metal solution.
End result a lovely ceiling but i wouldnt wanna have a shower in there with literally tonnes of stone above your head.....
i might add that this method is painfully slow and a 2 man job.
Good luck
