Discuss Tiling a Commercial Kitchen Floor Advice in the Canada Tile Advice area at TilersForums.com.
darrenmkn
Hi, I see you are an experienced tiler on this forum. I would appreciate any help you can give.
I have an industrial kitchen floor to tile, approx 7m x 10m. There are drains that the tiles need to fall into.
I have experience tiling domestic bathrooms and kitchens, but not industrial work.
Would i need to put a fall in the floor for water run off along the whole floor, or keep the floor level and then make a small fall about 1 meter from the drain?
Would i need specialised cutting equipment for the tiles, I have a rubi wet cutter that works frine on domestic tiles and a ts60 rubi dry cutter?
Would i need put down a membrane under the tiles to give the floor strength? Its a concrete floor.
Do i need expansion joints in the floor?
Many thanks if you can help.
Darren
bugs183
Find out what the kitchen is used for, and wether the room needs full falls.It sounds like you've been made aware about the falls, and that the floor needs to work to them. Ideally the floor should have these falls already in place and you should just turn up and tile, unless you are responcible for the screeding. This floor is way too big for you to try and create full falls, only small ones as the lads say.
darrenmkn
Thanks for replies.. Just a couple of more questions..
1) As the floor spans a large area, should i use expansion joints? If so, should they be set at certain distances?
2) Should i use a membrane underneath the floor? ie schluter ditra membrane
3) Do i need to use certain primers on the concrete, or would regular PVA do?
4) Would i need to use stronger adhesives, specifically for a commercial kitchin?
Darren
Reply to Tiling a Commercial Kitchen Floor Advice in the Canada Tile Advice area at TilersForums.com
    Votes: 6 4.5%
    Votes: 11 8.3%
    Votes: 8 6.1%
    Votes: 38 28.8%
    Votes: 16 12.1%
    Votes: 32 24.2%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.4%
    Votes: 18 13.6%
    Votes: 15 11.4%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
