Discuss Tiling Around All 4 Walls and Keeping Things Level in the Canada Tile Advice area at TilersForums.com.
Weebisto
Hey guys, being relatively new to tiling professionally and having taken on a job that was honestly a step too far too soon, I have been concentrating on floors and single walls and have built up my confidence again. I am gonna practice at home doing four walls in small wc. My question to you seasoned pros is if - as is likely - the four walls are not exactly level and exactly square, although I have developed my technique for getting my starting square point on one wall and working from there, what is the trick for extending that around the other three walls so that all the grout lines meet?
May sound basic but is pretty fundamental. Thanks
Wes
Hi weebisto use a couple of different size of levels 4ft,6ft,2ft whichever fits in room transfer level line from one wall continue round room or use laser if you have one. Take a couple of courses round at a time so that your confident that everything's lining up nicely.double check level on tiles every now and again. Hope it goes well keep us posted. Hope this helps.
Chris N
268
Nuneaton
Check to find the lowest point in the floor before setting battens around the room.
Also, dont take it for granted that your battens although may be 'level' might not be perfectly straight, so after laying your first row, put a level across the top of the tiles to check overall level, but also use as a straight edge to check the tiles meet the straight edge. I've been using mini tile wedges recently to shim and make small adjustments. Over the course of several rows, little discrepancies can cause larger errors.
Dumbo
I'm going to go a bit @timeless john on you and suggest you go on a tiling course because the sort of questions you are asking on this forum would suggest you don' have the basic fundamentals of tiling and you are trying to pass yourself of as a professional . Sorry to be negative but it's how I see it .
Just Rizzle
the first thing i always do is set a datum line around the room usually a meter from the lowest point in the floor from this you can work all your levels the second is to centre your walls this will allow u to work out your cuts top bottom left and right. these are lines to measure from not always to start from.
also get good levels and of various sizes
This reminds me of when working in a tile shop many moons ago
When a customer asked our advice about his problem
It seems he just started at one point and just tiled around till he met the starting point
Seemed he did not put a datum around the room so when he got back to the starting point the tiles and border tiles were about 20mm above where he started :oops:
Chris N
268
Nuneaton
That's the classic. Seen plenty of pics of similar scenario with picture rails etc
TheAofT
263
Reading
Totally agree with you
Time's Ran Out
@jcrtiling - I agree with your comment about unskilled people charging for a professional job, but I’ve never recommended anyone go on a course to learn my trade!
In this instance @Weebisto is practicing on his own property so fair play to learn, but better if put in the DIY section.
Thanks for the mention though as I was feeling a bit lonely sitting eating my mince pie and coffee.
Weebisto
Hi all thanks for your comments. All really helpful. @timeless john I totally take on board your suggestions about going on a tiling course as it seems like I don't have a grasp of the fundamentals. I've been on a course and for the last few months I've been restricting myself to splash backs, single walls and floors. My pricing has reflected my level of experience and I've been open with people I've done work for. I took on a bigger job - full bathroom - and nothing was level or square and, as I alluded to, it didn't end well as it was a step too far too soon. I'll openly admit that and it cost me money to get it put right. In terms of my grasp of fundamentals, if I didn't have a grasp of the whole thing I wouldn't have been able to do what I've done already but it's absolutely fair to say I clearly didn't have a grasp of going around the four walls which is why I've asked the question here. If I can get a steer from you guys and practice that at home to get my confidence up it will be a huge steps forward. I have also arranged to do a couple of weeks free labour with a local experienced tiler early in new year to get hands on training in the fields I agree that it's wrong to try to pass yourself off as an experienced professional but everyone has to start somewhere.
Reply to Tiling Around All 4 Walls and Keeping Things Level in the Canada Tile Advice area at TilersForums.com
Does anyone have a DIY link or suggestions for removing just a single central tile from a...
I'm doing a "meantime", part improvement job in own small bathroom after sink unit / wc change...
Hi all, I had my bathroom tiled about 5 months ago and yesterday I noticed cracking in the...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
