Discuss Tiling around door without architrave in the Canada Tile Advice area at TilersForums.com.
JohnMar79
Evening
Does anyone know how to tile around a door frame that has had the architrave removed and won't be put back i.e the tiles will run up to the inside edge of the frame close to the door itself? My thoughts were like tiling a window to square the door frame off and then put the trim in but unlike a window the trim has to go in with the return slotted in behind the tiles leading to the problem of getting the adhesive thickness correct so there is no lippage between the tile and the trim.
mr white
I agree above, architrave gives a nicer finish. I would extend the door jambs out (pin and glue) and tile up to it, then finish with architrave. Just makes sure your new timber is slightly proud on the internals then sand it back flush, quick job and it gives you plenty of play with all your cuts so might even save some time.
You can purchase PVCU Architrave, Which would be perfect for wet room etc as well.
This door has no architrave, it has two L cuts over it. I polished the edges back to a close factory finish and did not stick it to the frame of the pocket door, but put a bead of Silicon between back of the tile and frame to give a nicer finish.
Blunt Tool
Reply to Tiling around door without architrave in the Canada Tile Advice area at TilersForums.com
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Need some advice on a wetroom repair. Tiler installed the tile trim too close to all the edges...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
