Simon.
Hello, it may sound a bit of a daft question but when you have to snap a ceramic tile across hole centres to fix it over pipes do you have to glue it together as it is fixed on the wall? If so I'm thinking superglue as anything else will be too thick and open the cut. I'm asking as someone at work has got wind of me wanting to take up tiling and wants me to finish their bathroom. The tiling I'm going to do is a continuation of the tiling around the bath so I can't set the tiles so the pipes are at the edge of a tile. As luck would have it two water pipes exit the wall nearly bang in centre of a 20 x 30cm. tile in full view. Thanks a lot!
