Discuss tiling around window in the Canada Tile Advice area at TilersForums.com.
tegs
Hi All,
I am not a pro tiler but have always wondered about the correct way to tile around a window. So far I have managed to do this without making a mess of how the window looks so I guess I should continue but I would like to know how the professionals would tackle it.
Any advise would be stored in the memory bank for the future.
Thanks in advance.
macten
1,158
Nottingham
You would normally consider the window a feature of the wall so for setting out you would centre the window - whether that is centre of tile at mid point or grout joint - whatever gives best cuts either side of window and ends of walls. If centre doesn't quite work then move it slightly off centre till it does or consider changing spacer size.
Also remember to square off the window with your tiles rather than follow the reveals as they are likely to be out. Tile reveals after you've tiled the face of the window wall.
If there's plenty of window frame to play with then happy days - can help with setting out and plaster board or backer board can be used to pack out reveals prior to fitting trim and tiling reveals.
Reply to tiling around window in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hello, first post, asking about career change and possible entry route into the industry. I know...
    Votes: 8 5.9%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.7%
    Votes: 16 11.8%
    Votes: 34 25.0%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.7%
    Votes: 18 13.2%
    Votes: 15 11.0%
    Votes: 7 5.1%
    Votes: 3 2.2%
    Votes: 4 2.9%
