Discuss Tiling behind and under a log burning stove in the Canada Tile Advice area at TilersForums.com.
BroughtyTiler
Hi,
I have been asked to tile under and behind a log burning stove...
I am happy with the hearth, it is a concrete plinth that I can tile directly onto but the problem for me is the back panel behind the stove.
The board that is there at the moment is very flexible which I have told them cannot be tiled onto...
Would you remove the panel and replace it? - With what???
Can you screw another fireproof/heatproof panel onto the current panel and then tile onto that?
Cheers in advance
Stephen
Boggs
1,118
Uk
There is no way that fire is installed correctly.
It looks like that has been cobbled into an old gas fire surround, the flues are not compatable
and rear flies should have a maximum of 6” of horizontal glue before a bend, that definatley looks longer from your photo.
Solid flued appliances must only be installed by a Hetas registered engineer and can be just as dangerous as gas appliances.
I would not touch it at all.
Boggs
1,118
Uk
It doesn't have to be installed by a HETAS registered person but does come under building control so would need signing off.
In some areas building control won’t sign installations off without a Hetas certificate.
Boggs
1,118
Uk
100% correct, but first hand experience of BC not signing off one I installed because I didn’t have a Hetas certificate because they were not sufficiently qualified to sign off themselves.
Daft I know.
Reply to Tiling behind and under a log burning stove in the Canada Tile Advice area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hi all, I'm looking to tile the entirety of our small patio area with either brick slips or...
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
