what
Is there any reason why you cant tile directly onto brickwork if you use plenty of good adhesive?
I have a shallow brick fireplace recess which i am preparing for a wood burning stove
It measures about 110cm H 65cm W and 30cm D.
I was considering just using cement board but i have some smart 10mm calibrated slate floor tiles left over from the kitchen which I have used for the hearth and i would also like to slap onto the recess bricks.
The brickwork is crappy but stable but i have cleaned it well and primed with mapei primer G.
I need to keep the thickness shallow because of the 30cm depth restriction so don’t want to tile onto dot dabbed cement board if i don’t need to.
Any opinions!
Any opinions!
