Guest viewing is limited
Discuss Tiling Exterior Porch Area Walls in the Australia Tiling Forum area at TilersForums.com.
gordybaillie
Good Morning
I have a job where the customer would like their exterior porch area walls tiled. The walls I guess are not directly exposed to the elements although the Porch area is open (no door as its a sheltered area at the front door).
The walls are painted render and I am looking for help on the preparation of these:
- Should I fit hardiebacker first?
- Scrap off paint to leave a surface the adhesive is able to bond to?
Thanks in advance for any help! - not got any pics to help you visualise im afraid.
H
hmtiling
Why would you NEED to prime if back to the render? Never primed render and done tons of exterior stuff.
To improve bond strength and regulate porosity which on a weak mix render I would do.
That's the first time I've heard priming referred to as complicated ;)
Sometimes things get overcomplicated.
H
hmtiling
Looking to start this job today and I am going to use Mapei Mapeker Rapid Set which I have never used before but seems to get good reviews.
Anyone recommend a good primer or do I not really need to prime the area?
Thanks!
It should say on the back of the bag whether to prime and at what ratio to water. They'll recommend a Mapei one which is best practice imho.
I wouldn't be using rapid set unless you're used to using it.
Reply to Tiling Exterior Porch Area Walls in the Australia Tiling Forum area at TilersForums.com
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
